Giddyd 1 Posted October 15, 2019 Do we have any 2 stroke jetting wizards here? I got my girl friend a yz 85 and bike is just fussy as hell with altitude. At sea level it starts just okay, has great throttle response and pulls well to Max rpm but stalls very easily. At higher elevations it has to be bumpstarted and borderline unrideable. Cuts out above half throttle like it's running out of fuel. Id really like to dial it in as well as possible for elevation from seal level up to 3000ft but I really don't know where to start with all the different fuel circuits. If someone local (I'm in escondido) was interested in helping me out and showing me the ropes I'd be forever grateful. Share this post Link to post Share on other sites
Bagstr 295 Posted October 15, 2019 https://thumpertalk.com/forums/forum/44-motorcycle-jetting-fuel-injection/ Here is reading while you wait for a body to pitch in. Share this post Link to post Share on other sites
robertaccio 436 Posted October 15, 2019 start with being sure all the mechanics are spot on and are baselined before chasing jetting, premix ratio to factory spec, spark plug , good gas, timing, fresh top end!!!!, good reeds, no air leaks. no oil seal leaks, PV set up if it has one...etc Get into a Yamaha manual you can find them all over the internet, rocky mtn atv is good spot to access. jet according the manual. from sea level up to 4000 ft you could be as many as 2 mJ sizes smaller. But best to use a manual chart or check the FMF jetting chart (sea level std jetting) The OEM manual will have a pressure altitude chart. For Example my YZ125 was jetted for 4k (McCain, Cahuilla etc) for a dez ride I would go 2 sizes up on the main jet with no other tweaks. I always mixed 32:1 with pump premium and never had any spooge dripping, but my YZ was dialed mechanically, always idled and started easily. BTW what year YZ85? start with OEM that will be safe at sea level, to go up to 3k probably 1 main jet size smaller. Pilot just keep it the same as OEM, std for air screw is 1.5, FMF spec may have some tips as well as Pro Circuit spec. I have found Pro Circuit tends to be on the leaner side which sometimes worries me, FMF is more conservative on the their chart. PS it could be a simple as just a jetting adjustment for altitude as simple as a clogged pilot jet or debris in the carb, or as deep as the top end could be done...with associated compression loss. Share this post Link to post Share on other sites
Giddyd 1 Posted October 16, 2019 Bike is mechanically sounds. Did a new top end. Reeds aren't frayed and look good. Carb is clean be fuel and spark plugs. It's a 2004 yz85. Speaking of mcain valley is it really 4k up? That's where the bike was really having trouble. Are the smaller two strokes more sensitive to elevation. I have an Atc 250r and a lt250r neither seemed to care about elevation as long as I wasnt above 3k. My ktm 525 seems to run the same everywhere but I get that 4 strokes are a different animal entirely? Share this post Link to post Share on other sites
Oracle 206 Posted October 16, 2019 Pull the carb and open her up, remove the jets, and inspect them all. It could be something as easy as a clogged jet. Compare your jet sized and needle position to factory specs. Post back with the details and we'll go from there. 1 Share this post Link to post Share on other sites
robertaccio 436 Posted October 16, 2019 What oracle said check float height as well FYI OEM is MJ 138 PJ 45 Needle NBKF-2 AS 2.375 Pro Circuit (leaner spec) set is better for the 4k altitude and for trail riding MJ 135 PJ 42 Needle same AS 2 could not look up FMF at this moment, but that PC one set smaller spec sounds good for local mountains at a trail ride pace. They spec for sea level at 65 degF with premium fuel with a MX ripper on the MX track = pinned in the power a lot. mix premium at factory spec PS any questionable issue about jets just buy new ones Share this post Link to post Share on other sites
SoCalMule 106 Posted October 16, 2019 Trust stock jetting settings. Soaking jets in gun cleaning solvent over night and using a clipped wire from a large wire brush to clear holes works well, so is good gas and proper oil mixture ratios. Air box free of obstructions, air filter clean and serviced. New spark plug and good wiring. Share this post Link to post Share on other sites
tntmo 971 Posted October 16, 2019 I use guitar strings for clearing jets, along with an ultrasonic cleaner for the carburetor body. Start with a good clean carb and stock settings, then adjust from there. Share this post Link to post Share on other sites
socalhodaka 115 Posted October 17, 2019 I’m in PQ and we just sold my sons YZ85, I can help out. Again you need to start at OEM baseline. PM me your info. Share this post Link to post Share on other sites
Giddyd 1 Posted October 21, 2019 Sorry for not getting back, worked through the weekend then went riding in ocotillo on sunday. The bike did better. I found out airbox boot wasnt sealing to the carb so another clamp fixed that which helped a lot. Still didnt feel like it was running 100 percent though. Socalhodaka I may need to take you up on that offer. Share this post Link to post Share on other sites
