• advertisement_alt
  • advertisement_alt
  • advertisement_alt
Reximus
XR650R crank balancer index
8 posts in this topic
Does anyone know where the balancer gear index notches are on a XR650R crank? I have nearly gone blind looking for them. The notches are obvious on the balancer gear, but I cant see them on the crank gear.
This isn't seen? is end gear on C/B shaft flipped? (dot on the other side?)
I can see the counterbalance mark. The mark on the crank gear that drives the counterbalance gear is the one that i cant see! Its driving me nuts.
I have been informed that it may not be "dots", but may be lines that I am looking for.
Rob, those pics are of a XR650L, different animal.
Rex, it's a dot on the balancer  and two small hash lines on teeth on the crank if I remember correctly, they are sort of faint and not easy to see when the bearing is installed.
Interestingly, the balancer has a dot AND lines! Ill send photos.
