350thumper 336 Posted September 2, 2014 Where is the original lighting that came with the bike ? 'just playin'. Share this post Link to post Share on other sites
Reximus 10 Posted September 2, 2014 The original system in a tiny stator with weak ass ac light. Tht stuff is all gone. Now habe RS 200 watt stator and trailtech RR. Share this post Link to post Share on other sites
Bagstr 288 Posted September 2, 2014 A clamp type Ohm meter will measure current or flow through a wire. Current flow produces heat. The clamp allows measurement without disconnecting the conductor. Measuring high current towards a system may help identify bad connections or components. That said, I suspect you have a bad battery or an over-charge condition. The heat in the batt is a result of too much current flowing from somewhere. Is the wiring hot as well? Your description seems to be a component heating up to a trip / open circuit condition. I am trying to imagine a device that would reset itself without blowing a fuse. Good luck Share this post Link to post Share on other sites
Reximus 10 Posted September 3, 2014 The wiring does not get hot. Only the battery and RR. The guys over at ADV forums said I need to ground the RR to the frame. Share this post Link to post Share on other sites
