ADAM_650L 0 Posted March 29, 2008 I have a 03 XR650L that is bone stock except for a K&N filter. Im gonna put the de-smog kit on and pull the snorkel. I will leave the stock exhaust for now. Can I just buy a 160 main jet and a 55 slow jet, or do I need to buy a whole kit with spring and all? Also, where can I find a shim for the needle? Any help/suggestions are appreciated Share this post Link to post Share on other sites
Chief Gunner 2 Posted March 29, 2008 I did 99% of the "Dave's" carb mods to my XR before I found it at 4strokes.com and did a few more things after reading the article there. Yes you can buy jets individually, it's a Kein Consant Velocity (CV) Carb and the jets available for it can be found at any stealership or most local shops. Vey's right here in Lakeside had what I needed. I used a small washer I had in a collection of miscellanous parts, nothing special required just the right thickness. I used a linear micrometer to figure the thickness of the washer I used to shim the needle. Shimming is required becuase the CV carb needle does not use a clip like the Kein flatsides and Mikuni's do. I also drilled the slide out with the recommended 5/32" holes after reading the "Dave's mods" With the carb mods and a K&N you will see a bit of throttle improvement but even more if you clean out the baffle flanges in the stock exhaust like Hondapilot did and you will see a decrease in gas milage as well but you will like the noticeable difference in "Grunt" Here's an excellent link on the CV carb mods: http://www.4strokes.com/tech/honda/xr650lcarbmods/ I'll be home working on my pig and around the garage today so you are welcomed to swing by if you'd like a hand with it, I PM'd my phone number and address to you. Share this post Link to post Share on other sites
carguy 1 Posted March 30, 2008 I have a 03 XR650L that is bone stock except for a K&N filter. Im gonna put the de-smog kit on and pull the snorkel. I will leave the stock exhaust for now. Can I just buy a 160 main jet and a 55 slow jet, or do I need to buy a whole kit with spring and all? Also, where can I find a shim for the needle? Any help/suggestions are appreciated I installed the Dynojet kit. No guess work needed. Here is a link,Dynojet There is a jet for air box mods and one for exhuast. I still have my stock exhaust. Share this post Link to post Share on other sites
