Koonzee 28 Posted November 16, 2025 (edited) $1200 (Retail is $2000 without tax and freight from Akron, Ohio) SD AdvRiders: Hello. Regardless of your age or strength... * protect your shoulders and back by utilizing a motorcycle carrier with a hydraulic lift; * ride or walk your motorcycle onto the carrier while the carrier is flat on the ground; * enjoy exploring a larger riding region with the convenience of a rescue vehicle or tow vehicle; * safely load and unload your motorcycle without assistance; * protect your motorcycle and tow vehicle/RV from damage due to dropping your motorcycle while loading or unloading a motorcycle onto a carrier with a steep ramp; * avoid maintenance and storage of a motorcycle trailer. Product Info from website: The 1000M is a great way to carry your 1000 LB motorcycle on the back of your RV, Truck, or fifth wheel. Designed by our engineering team with AutoCAD and manufactured in the USA in our plasma CNC facility. No details have been over looked. The Mighty Hauler 1000M motorcycle carrier uses the industries only “Sway Lock” technology to ensure the motorcycle does not sway during travel. The “Sway Lock” makes strapping the lift to the vehicle unnecessary. The “Sway Lock” pin is ¾” and also works as a safety pin taking pressure off of the cylinder. Everything on the Mighty Hauler is CNC cut to a ten thousandths of an inch. Nothing is hand cut. This allows us to custom create each piece which gives the Mighty Hauler the strength and stability it needs. Once you own a Mighty Hauler RV motorcycle carrier the quality will speak for itself. When you choose the Mighty Hauler 1000M motorcycle carrier there are no attachments that cost extra money. Everything is included. The Mighty Hauler 1000M has been engineered to lower to within 1” from the ground allowing us to build the loading ramp right on the storage platform. This means there are No Extra Parts needing to be stored or carried. You also do not have to deal with trying to drive an 800 lb. motorcycle up a steep incline. The platform is 8” across and 81” long, which makes it large enough for the widest tires and longest bikes. The hauler also includes brackets for storing the jack handle. The Mighty Hauler 1000M RV motorcycle carrier has a standard 2” hitch receiver to flat tow a car up to 5,000lbs with the addition of the three point hitch. Brake lights and turn signal lights are included but not installed. The Mighty Hauler 1000M has a carrying capacity of 1,000 lbs. The hauler comes powder coated and ready to go. The hauler comes standard with a 2-1/2″ solid steel tongue and fully welded gussets to hold the tongue to the upright for added strength and support. The hauler has over 18” of travel and the motorcycle platform will be raised to a full 4” above the hitch for plenty of ground clearance. The main upright tube has two extra holes for extra tie down stability. Four tie down loops are integrated into the design for both added strength and stability. This is much stronger and safer than simply welding tie down brackets on. The industries only Sway Lock system Plasma CNC quality Made in the USA Can be left or right side load No extra parts to lug around 1,000 lb Capacity Built in ramp 3 ton lift jack Comes fully powder coated Added hooks and holes for easy strapping 3” Main upright Tube 2” Receiver Reinforced 2” Solid steel tongue The 1000M weights – 280lbs Lowers to within 1” of the ground High Strength grade 8 hardware Three year warranty on manufactured parts Three point hitch available for flat towing We recommend that this hauler be used by vehicles with a class IV or V hitch. The heavier the hitch the better. The receiver size needs to be 2-1/2” square or 2″ with the 3 point hitch option. Please consult with your vehicle or hitch manufacturer for complete requirements and specifications for your specific hitch. Mighty Hauler is the premier manufacture of RV and truck motorcycle carriers. Manufactured here in the USA, we have been building carriers for over a decade. Mighty Hauler products come with Sway Lock or Lock Tight technology, which allows our carriers to withstand the toughest road and not move around behind your truck or camper. Our patent pending design allows us to make great carriers at an affordable price. All Mighty Haulers are plasma CNC cut giving us the ability customized every part. Our ability to make every piece to a ten thousandths of an inch, allows us to give our motorcycle carriers the strength and stability you deserve. Mighty Hauler offers a variety of products ranging from motorcycle carriers, Golf Cart Carriers, Trike Carriers, and more. Our RV motorcycle carriers and truck motorcycle carriers can be placed on the back of trucks, fifth wheel campers and RV’s so you can take your toys anywhere. Mighty Hauler motorcycle carriers come with a capacity range of 600lbs. up to 1000lbs. Our golf cart carrier and trike carrier have a capacity rating of 1200lbs. All of our RV carriers have the capability to tow a car behind them with the addition of a three-point hitch. Each product has been designed by our engineering team and has been produced in our state of the art facility with state certified welders. Mighty Hauler offers our lifting motorcycle carriers in both manual power and electric power giving everyone the ability to operate their carrier. Custom modifications are no problem. Just use our contact page and contact us with what you are looking for and you too can have the perfect motorcycle carrier. Mighty Hauler strives on developing the best so make sure you continually check the website for new and exciting RV motorcycle carriers and truck motorcycle carriers. Mighty Hauler: 1000M Motorcycle Carrier Manual Retail Price $1975.00 (Without sales tax & freight from Akron, Ohio) https://mightyhauler.com/ Edited January 3 by Koonzee price update Share this post Link to post Share on other sites
Koonzee 28 Posted December 27, 2025 (edited) Hello and happy holidays. The powder-coated and painted items of the hydraulic lift motorcycle carrier have been assembled. My online gallery of the reconditioned motorcycle carrier:https://www.smugmug.com/gallery/n-DmZwTd More info from the mfr:https://mightyhauler.com/ The main red rail where the motorcycle rides was powder-coated with an anti-corrosion paint and then powder-coated with the red paint. The two black diamond steel platforms were powder-coated with an anti-corrosion paint and then powder-coated with the high gloss black paint. The frame of the motorcycle carrier was prepared for painting by: 1. using a scrapper to remove chipping or flaking paint. 2. using an orbital sander to remove any rust or additional flaking paint. 3. applying RUST AID rust removal which changes the chemical composition of rust. 4. applying RUST-OLEUM paint thinner / mineral spirits. 5. applying two coats of RUST-OLEUM black primer . 6. applying two coats of RUST-OLEUM high gloss black enamel. https://www.smugmug.com/gallery/n-DmZwTd Includes: 1. Three hitch receivers. (Main receiver and two out board receivers.) 2. Two new stop and turn indicator lights (Relocated for better mounting with spacers.) 3. CURT hitch with 2" ball. 4. Stainless steel hardware. 5. Electrical wiring with wiring loom & maintenance loop future maintenance. 6. Light plug extension for more flexibility while using hydraulic lift while assembled. $1200 Edited January 3 by Koonzee price update Share this post Link to post Share on other sites
Koonzee 28 Posted April 7 Sold! Thanks San Diego Adventure Riders, Share this post Link to post Share on other sites
