Mikey777 44 Posted May 30, 2019 This is an interesting video and worth the watch. Share this post Link to post Share on other sites
KTMrad 578 Posted May 30, 2019 Good vid...I've been using nothing but 90 wt. gear oil for years. Share this post Link to post Share on other sites
Bp619 112 Posted May 30, 2019 Nice vid, I've been doing wd40 clean and spray after for rust and just replace chain and sprockets at 100hrs. Never failed and all chains still within specs when replaced Share this post Link to post Share on other sites
KTMrad 578 Posted May 30, 2019 I've never used WD40....it's a penetrant, can get thru the o-rings or x-rings and dilute the internal grease....so they say, lots of debate about it. I'd just prefer not to use a penetrant. Share this post Link to post Share on other sites
Bagstr 295 Posted May 30, 2019 This tread usually appears in late summer, not late spring. Share this post Link to post Share on other sites
robertaccio 436 Posted May 30, 2019 same as an oil thread..... when I go into full restore mode ---clean chain with maxima degreaser (red can) and grunge brush, wash off, spray with maxima spray lube (yellow can), wipe and basically dry off, spray on Spectro Z clean chain lube. The usual most of the time, wash bike spray on Spectro Z clean go ride. Oil thread time. BTW I use Maxima products with only minor exceptions. Share this post Link to post Share on other sites
Mikey777 44 Posted May 30, 2019 4 hours ago, Bagstr said: This tread usually appears in late summer, not late spring. Lots of rain this year makes for dirty, grimy chains... Share this post Link to post Share on other sites
dirt dame 589 Posted May 31, 2019 Maxima Cain Wax for the street bike and Yamalube Offroad chain lube for the dirt bikes. Share this post Link to post Share on other sites
TexasDualler 32 Posted May 31, 2019 Guess I've been doing it wrong all these years. Being a neat freak, I've always used BelRay SuperClean because I really like that it doesn't make a mess but it looks like it's time to make a change. I can attest though that my chains do last and have minimal stretch using BelRay. Share this post Link to post Share on other sites
Bagstr 295 Posted June 1, 2019 I can Also attest that my chains last over year with no maintenance other than a stiff brush. No collection of gunk. 100 hour chain and sprockets. There you got me. Share this post Link to post Share on other sites
Ptkatoomer 118 Posted June 1, 2019 Back in the 70's one of the local pros in the desert would slather his chain in some really heavy grease and then hit it with a blow torch to melt it into the links. We used to soak 'em in gear oil and then hang them up to drip dry. Now it's WD, chain lube and replace as necessary. Share this post Link to post Share on other sites
paulmbowers 236 Posted June 2, 2019 On 5/30/2019 at 6:08 AM, Bagstr said: This tread usually appears in late summer, not late spring. And yet some say climate change is a myth. Share this post Link to post Share on other sites
